Results 1 to 2 of 2
    Exclamation Google Play store problem...
    Hello,
    I have a huawei asc g510, yesterday I rooted it and bought the Rom toolbox of jrummy in the g.play store.Then the next day my gmail and google play store didn't work(it just exites at startup), i tried the clear cache and force stop function ...no help, i saw the disabled/enabled downloads function in the app manager still it didn't work,then i deleted the play store entirely with the rom toolbox and reinstalled it with an google play apk from the androidpolice site , still it didn't work..and I went to a factory reset, the google app wasn't on the phone and i couldn't login on gmail, i tried the hosts trick to put the # in front of the second ip, it just helped with the gmail login, so i downloaded from the same site g.play AND STILL IT EXITES, I even tried to flash those gapps from xda and it says installation aborted...
    I don't know what the heck am i going to do next...any suggestions please?
    Best regards,
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Google Play store problem...
    You need too reinstall a stock rom. Check the development Forums for your device and see if there's any way to restore back to stock.
    Otherwise, you can try side loading those apps and see if you can load it that way.
  1. nexus 7 auto-rotation problem
    By Janardhan Yaduvanshi in forum Android 4.4 KitKat
    Last Post: 11-24-2014, 02:01 PM
  2. Samsung s4 i9505 music player problem
    By Emil Kolar in forum Samsung Galaxy S4
    Last Post: 08-14-2014, 03:53 AM
  3. Title for Google now
    By eric002 in forum Moto X (2013)
    Last Post: 04-07-2014, 08:42 PM
  4. Replies: 0
    Last Post: 04-05-2014, 01:40 PM
  5. Manic Runner on Play Store
    By Kleomenis Kakkalos in forum Android Games
    Last Post: 04-05-2014, 11:06 AM
