1. Gail Wood's Avatar
    Hi my phone has just started doing weird things. The date has gone back to January, the time is way out and when i send a message it disappears, when i receive a message they too disappear so I cant read them I have re-started turned on and off taken the battery out nothing seems to help.
    04-05-2014 10:05 PM
  2. Johnly's Avatar
    My wifes s3 has a time issue. It shows 2 hours backwards, but then adjust to the right time. I am tempted to factory reset it for her and see.
    04-05-2014 10:39 PM
  3. milan patel2's Avatar
    04-05-2014 11:41 PM
  4. srkmagnus's Avatar
    Go to Settings, time then see that the device is set to adjust manually or be based on network. Adjust Accordingly and see if that fixes the problem. Otherwise, consider a reboot.
    04-06-2014 10:25 AM
  1. Verizon LG G2: WiFi Problems
    By InboundPotato in forum Verizon LG G2
    Last Post: 08-17-2014, 10:17 PM
  2. Verizon Galaxy S4 - White - Rooted + LOKI - Lots of Accessories
    By willstilson in forum Marketplace Archive
    Last Post: 04-15-2014, 02:27 PM
  3. Instaling Kies on S4 Mini
    By s4mini in forum Samsung Galaxy S4 Mini
    Last Post: 04-05-2014, 06:52 PM
  4. straight talk s4 active apn issues
    By waregurl in forum Samsung Galaxy S4 Active
    Last Post: 04-05-2014, 06:28 PM
  5. S4 Mini
    By rohankmehra in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-05-2014, 05:57 PM
