Go SMS Pro help/support
illingd
I'm using Go SMS and have a problem since latest update. Is there somewhere around here I can appeal for help? Or does anyone know how to get Support from the developers?
Thanks.
neonworm
2,757
To email the developers you have to go to the app in the Google Play store and then scroll to the bottom of the page. At the bottom, there should be an "Email the developer" option or something similar. When you push it, it will start an email to them in your default email app.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Thanks.
Hello, welcome to the forums!
Here is the Go SMS support website: GO SMS Pro
Here is the Go SMS Google Play Store Page where you can email the developer should you have a question: https://forums.androidcentral.com/e...e/apps/details?id=com.jb.gosms&token=BSEP0wYM - scroll down to "email developer".
Hope this information helps :).
samahmed336699
