Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By srkmagnus
    Default Problem with my drive
    Hello,I cant update my drive for samsung, I cant connect my phone (Samsung Galaxy Mega 5.8) to my pc. I want to transfer music to my phone, I've been using it for almost 6 months now and I have never experienced this problem before, I recently added a song a few days ago and now I cant seem to connect my phone anymore.(Im not using Kies).Click image for larger version.
    please help me
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Problem with my drive
    Have you updated the drivers? If not, go to the Samsung website for the device and download the appropriate drivers and install/update: GT-I9152 - DOWNLOADS | SUPPORT | SAMSUNG
    Hopefully that helps. In the meantime, perhaps consider using a wireless transfer application such as WiFi File Explorer - Google Play Store to pull your files to and from the device.
    Golfdriver97 likes this.
    I gave up on fixing this problem, I think the problem is my usb ports, I tried inserting a USB on one of the ports then the computer didn't recognize the device either.
  4. #4
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    Quote Originally Posted by ejong321 View Post
    Ports, plural?
    A phone only has one (micro) USB port.
    So you mean you suspect the USB port(s) on your PC is/are knackered?
    How about another USB port on your PC? Tried those?
    And if you got problems transferring stuff over USB cables, wires, why not try a wireless connection? Like via Dropbox, or Airdroid, or WiFi File Transfer, or SonicShare, etc. The Play Store is full of 'm.
    I tried installing the file I downloaded from the site,and this error pops out,my phone is not connected to the computer but still this error pops out,i tried restarting my pc and still this error comes up.
  6. #6
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    You will really need to be a lot more clear, detailed, and precise on what your situation is, what you do, what you want to do, and what is happening.
    For instance what file did you download and are you apparently trying to install? From what site did you download it? What version of Android are you running?
    My PC doesn't recognize my device when I connect my phone using the cable that came with it. It charges when I plug it to my PC but it doesn't allow me to transfer files.
    On my phone it is connected as as Media Device.
ID:	111553Click image for larger version.
    This is the program I downloaded from SAMSUNG.
  8. #8
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    That is the right file for drivers. Have you tried a different cable?
    I haven't tried a different cable yet. But thanks I will try to buy a new cable.
  10. #10
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Moto Cables (at least the stock one I got with my X) are pretty thick.
    Eco Friendly USB Cable by Motorola - A Google Company
    Or you can try on our site: Motorola Moto X Chargers & Cables - ShopAndroid
  11. Thread Author  Thread Author    #11
    I brought the original USB cable of my phone to a SAMSUNG store. It worked fine on their PC. They told me that my PC may be the problem.
  1. What things to look out for while receiving my tablet?
    By JamesM90 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-19-2014, 02:53 PM
  2. Language and location issues in Google play store on my PC
    By briancook451 in forum Google Play Store
    Last Post: 06-15-2014, 12:08 PM
  3. Samsung Galaxy S4 Wifi problems
    By thefreak75 in forum AT&T Samsung Galaxy S4
    Last Post: 04-14-2014, 04:34 AM
  4. Gmail app - trouble with sync
    By Jerry7650 in forum General Help and How To
    Last Post: 04-08-2014, 03:45 AM
  5. Please delete
    By Villordsutch in forum Samsung Galaxy S4 Mini
    Last Post: 04-07-2014, 09:37 AM
