1. hana amiri's Avatar
    Hello,
    I am trying to run some audio tests on smartphones. what i want to do is to generate a tone from the phone's speaker AND record it by the same phone's microphone at the same exact time.
    the tone generations runs pretty well, but is it possible to self record?
    any ideas?
    04-11-2014 03:00 AM
  2. mrsmumbles's Avatar
    You could try a call recorder. Also I use an app called Sound Recorder for ambient recording. I don't know if it would record what another app does, though, but you could try it.
    Sent from my LG-LG870 using Tapatalk 2
    04-11-2014 03:05 AM
  1. Car and USB Audio Out
    By Sasazuka in forum Samsung Galaxy S4 Google Edition
    Last Post: 01-18-2015, 02:02 PM
  2. Replies: 10
    Last Post: 04-26-2014, 08:48 AM
  3. anyone tested Bluetooth audio? apt-x isnt on specs
    By fredknex in forum Samsung Galaxy S5
    Last Post: 04-10-2014, 12:26 PM
  4. Media audio through phone speaker?
    By intoaction66 in forum Android 4.4 KitKat
    Last Post: 04-09-2014, 09:30 PM
