Results 1 to 5 of 5
    TryToDecide's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default File Lock?
    Hello all...
    I need a Simple file locking app.
    All I need is the following:
    1. Stop anyone/anything from Editing, Moving, or deleting the file
    2. Password needed to View the file
    Thanks in advance
  2. #2
    davidnc's Avatar
    Posts
    Global Posts
    8,985 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: File Lock?
    Quote Originally Posted by TryToDecide View Post
    Hello all...
    Thanks in advance
    Welcome , to AC
    Something like this ?
    I just saw it ,I haven't tried it.
    https://play.google.com/store/apps/d....applock&hl=en
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, I saw that one as well. What I need is a basic app/tool
    to keep a single file from being Deleted, Edited, or Moved
    Also, a password needed to View the file
    Thanks again
    Mike
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    If you put a period (.) in front of the filename it should make it a hidden file. No one will know it's there. Or, you can use an App to password lock the file manager and Play Store so the files not accessible. There should be something along the lines of what you want, I just don't know if one for that specific purpose and it seems like you have looked through the play store already.
    I'll keep a look out in the play store and post anything I think is what you are looking for.
  5. #5
    LaymansPulse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try this to lock your files, photos and videos: Android File Locker (Free): Save/Hide Files Inside a Locker
  1. Remove My Magazine from Lock Page
    By sdpliskin in forum Samsung Galaxy S5
    Last Post: 05-21-2016, 06:08 AM
  2. Moto G lock screen wallpaper
    By jeanlucpicard22 in forum Moto G (2013)
    Last Post: 10-11-2014, 06:45 PM
  3. Replies: 38
    Last Post: 06-21-2014, 04:08 PM
  4. Camera opens at lock screen
    By Cyberdelia in forum HTC One M8
    Last Post: 04-11-2014, 03:10 PM
  5. File extensions not supported
    By suxen01 in forum Nexus 10 Rooting, ROMs, & Hacks
    Last Post: 04-11-2014, 01:35 PM
