Results 1 to 2 of 2
    Default Unplugged while automated rooting program running
    I have a galaxy note i717 and it was unplugged while an automated unrooting program (kingo android root) was running. Now the phone is stuck at the "Firmware upgrade encountered an issue" screen, and Kies won't connect to the phone.
    Is there anything I can do to get the phone working again?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,694 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Unplugged while automated rooting program running
    Quote Originally Posted by Rouault View Post
    You should try flashing a stock firmware with Odin and see if that will take. If you could booting download mode then this is possible. Power off the phone then hold volume down plus power on. You should see an option to be in download mode. If not, then there was a major error when the device was pulled while the program was running. Perhaps when the device was being formatted and it didn't complete.
    If that's the case it's likely bricked and can't be reversed.
  1. HTC One (M8): Heads Up on the HTC Advantage Program
    By jeffdanger in forum HTC One M8
    Last Post: 04-13-2014, 04:51 PM
  2. Bought a rooted sprint galaxy s4 and would like to stock It out.
    By ESA85 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-13-2014, 08:18 AM
  3. help finding rooted stock rom
    By jcole01272 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-13-2014, 04:30 AM
  4. Bought a rooted VZW S4 and would like to return it to stock
    By ammarmon in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-12-2014, 10:16 AM
  5. Sprint Galaxy S5 already rooted!
    By Joe113 in forum Samsung Galaxy S5
    Last Post: 04-12-2014, 01:20 AM
