1. danis2142's Avatar
    I tried to flsh stock rom to my device cos I didnt need paranoid android anymore, but it failed and since then whenever it reboots, I get lbank screen after the bootlader unlcoked window. My pc cant detect the device, so first of all how can I get it to see my sd card? I already wiped out everthing and factory reseted from clockworokmode recovery but still nothing helps!!
    04-13-2014 08:51 AM
  2. mike p4's Avatar
    im sorry to inform you that this is becoming a common problem and as of yet there is no remedy. the not detecting device issue is either drivers or a lack of OEM cable. But i have flashed stock firmware to the Moto G to no avail. Everything flashes just fine, but it continues to loop before it gets to ANY options in Fastboot menu. So it is a bootloop that is yet to be solved. Sorry.
    06-16-2014 10:13 AM
  1. Moto G: KitKat signal strength indicator erroneous?
    By AM_SOS in forum Moto G (2013)
    Last Post: 01-27-2015, 07:15 AM
  2. Using the Moto X without a case
    By charlyee in forum Moto X (2013)
    Last Post: 07-06-2014, 08:04 AM
  3. Does Verizon Offer a Brand That Gets Reception As Good or Better Than Moto?
    By Murph5150 in forum General News & Discussion
    Last Post: 04-17-2014, 06:47 PM
  4. Moto G or Razr i??
    By honeyfleur in forum Moto G (2013)
    Last Post: 04-17-2014, 11:33 AM
  5. Razr i or Moto G?
    By honeyfleur in forum Motorola RAZRi
    Last Post: 04-12-2014, 09:49 AM
