1. pollensa1946's Avatar
    Motorola Moto G.
    I spent a considerable time and effort attaching photos to all my 100+ contacts. These photos were crops from larger photos so, stupidly in hindsight, I did not preserve any of them. I would like to copy all my contacts, complete with photos, to another phone. Copying the simple contact info is easy via the Gmail export/import procedure, but that does not copy the attached photos. Is there a simple way of copying contacts complete with photos?
    04-14-2014 01:21 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are all of your contacts on your old phone saved to your Google account, or to the Phone Account? If they're saved to your Google account, then they should be synced with your Google Contacts in the cloud, and I believe the photos should also be synced as well. You can go to Google Contacts on the web and see if the photos are associated there. If so, then they will all sync to your new phone, as long as you log in with that Google account.
    04-14-2014 01:43 PM
  3. pollensa1946's Avatar
    Thanks, that worked no problem.
    B. Diddy likes this.
    04-26-2014 05:03 AM
  4. rapso's Avatar
    You can use apps Bump.
    04-26-2014 11:07 PM
  1. How to restore contacts?
    By josephflan in forum Samsung Galaxy S4 Mini
    Last Post: 12-18-2016, 02:46 PM
  2. Deleted Photos Keep Returning
    By The Harrington in forum HTC One M8
    Last Post: 01-12-2016, 10:36 PM
  3. Bricked phone - have access to bootloader and recovery, but no root and a corrupted OS
    By jazzgeek444 in forum HTC One X Rooting, ROMs, & Hacks
    Last Post: 04-23-2014, 12:58 AM
  4. Replies: 0
    Last Post: 04-14-2014, 01:15 PM
  5. [FREE] Bluetooth Phone Hacker
    By cinq labs in forum Android Apps
    Last Post: 04-14-2014, 12:48 PM
