Results 1 to 2 of 2
    neil154's Avatar
    Posts
    Global Posts
    505 Global Posts
    Default MailDroid
    I am thinking of switching from POP to IMAP for my 2 email accounts on my S3 and have a couple of quick questions for you.
    1) I cannot find the place where I set the maximum number of emails (or length of time, dont remember which is use) so please guide me to the setup.
    2) With IMAP is every folder syncd or can I specify only some?
    3) Is there any reason you would suggest that I do NOT switch to IMAP?
    Thanks for your help!
  2. #2
    Default Re: MailDroid
    1. IMAP is very different than POP3, you don't really need to set this
    2. You can specify
    3. No, if you have IMAP, unless there is a good reason to use POP, I always suggest IMAP.
  1. How to delete unread email in MailDroid
    By samrap in forum General Help and How To
    Last Post: 04-02-2014, 01:39 PM
  2. MailDroid Asterisk *
    By LillianBehj in forum Android Apps
    Last Post: 03-03-2014, 05:16 PM
  3. Anyone get MailDroid notifications to show up on the Gear?
    By rishman1 in forum Samsung Galaxy Gear
    Last Post: 10-24-2013, 04:32 PM
  4. Help w Maildroid - only gets old mail -??
    By mikesmithfl in forum General Help and How To
    Last Post: 07-04-2013, 11:38 AM
  5. Help w Maildroid - only gets old mail -??
    By mikesmithfl in forum Android Apps
