1. Maxim Stratan's Avatar
    Hello, i just purshased my first android tablet (never had android before) and i wonder if someone can tell me how to remove the volume up and down icons from that black bottom bar (where are the home button, back...etc) because i have phisical key to do that job. Another icon that i want to remove is the snaphot. I searched here on forum but didn't find anything. Thank
    04-16-2014 11:23 AM
  2. JRDroid's Avatar
    What tablet do you have specifically? Neither of those buttons is a standard Android button, but a manufacturer add on. So determining how (and if) they can be removed will require knowing what make/model your tablet is.
    B. Diddy likes this.
    04-16-2014 11:37 AM
  3. Maxim Stratan's Avatar
    Thanks, for reply. I have eZeeTab785 by Storex. This tell you anything? xD
    04-16-2014 12:09 PM
  4. JRDroid's Avatar
    It tells me a couple things, mostly that you probably aren't going to be able to turn them off. Off brand tablets are extremely difficult to find information on, so even if the setting to turn them off exists, it will be next to impossible to figure out without the tablet in front of me.
    04-16-2014 04:20 PM
  5. STARGATE's Avatar
    Welcome to Android and to the forums!
    Yes, without having the same tablet is difficult to say for sure.
    However, you said icons, did you mean actual icons on the screen?
    If so, you can long press for a second on the icon and you'll see an option on top of the screen to remove that icon from there.
    Try it and let us know if that worked for you.
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    04-16-2014 04:36 PM
  6. Maxim Stratan's Avatar
    Hello, no, i mean icons in the bottom bar. I will try to find info in xda. Thanks anyway guys
    04-18-2014 05:45 AM
  1. HTC One M8 and Ingress
    By InfinitiGuy in forum Ingress General
    Last Post: 04-17-2014, 10:27 PM
  2. Bought a second-hand One, first time and need help
    By Wayne Cheah in forum HTC One M7
    Last Post: 04-17-2014, 04:51 AM
  3. 25% off accessories sale at T-Mobile includes Gear 2, Neo, and Fit
    By JimSmith94 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-16-2014, 07:08 PM
  4. touch and screen lagtimes
    By fairfieldwizard in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-16-2014, 05:48 PM
  5. B1 File Manager and multiple Dropbox accounts
    By eggantom in forum General News & Discussion
    Last Post: 04-16-2014, 10:00 AM
