1. fonepad7's Avatar
    i was unable to unhide apps which i have clicked hide option on the appdrawer screen...i found them in appbackup file..plss helpme out to unhide apps and see them again on screen :-(
    04-17-2014 05:15 AM
  2. Kelly Burby's Avatar
    Well, you need to goto the menu and on the top right corner you'll be seeing an button press that you'll find an option unhide applications click on that and unhide the application that you've have accidentally hidden.
    fonepad7 likes this.
    04-17-2014 05:45 AM
  3. fonepad7's Avatar
    thank you.but unfortunately its not showing unhide option it's just showing hide and lock options only.i found all my apps in app backup folder there it shows backup/restore app data :/...i can open my game and other installed apps only through playstore..now..
    04-17-2014 05:59 AM
  4. JRDroid's Avatar
    Have you tried clicking the hide option again to get to the screen where you select what applications to hide, then unchecking the apps you no longer want hidden. That is how you unhide apps using Nova Launcher. While I have never used ASUS's version of Android, I would think it would be done in a similar manner.
    04-17-2014 06:18 AM
  5. fonepad7's Avatar
    wow!!! thank you jd ..it really worked for my asus too :-)
    04-17-2014 06:24 AM
  6. JRDroid's Avatar
    Glad to help
    04-17-2014 08:05 AM
  7. neha agarwal2's Avatar
    please help me out my lock app is not working in asus zenphone5
    11-21-2014 11:53 PM
  8. laxman soodam's Avatar
    02-20-2015 06:08 AM
  1. Replies: 3
    Last Post: 04-28-2014, 05:19 AM
  2. help me :-(
    By fonepad7 in forum Introductions
    Last Post: 04-23-2014, 01:09 PM
  3. Android users...please put me at ease
    By mmmcheesedanish in forum HTC One M8
    Last Post: 04-21-2014, 05:35 PM
  4. Verizon One Max-- Should I Update to KitKat or No?
    By giovanni6 in forum HTC One Max
    Last Post: 04-18-2014, 09:43 AM
  5. Next Galaxy Note to feature a new form factor?
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 04-17-2014, 05:56 AM
