I have a new Galaxy S5 with a 64GB SD card that I'm trying to load up with my music library.
I formatted the SD card in the phone, created a Music directory on the card, plugged the phone into the PC using the USB cord and started moving files using Windows. When I tried to play the songs, some of the files were fine and other sounded skippy or choppy. Then I took a closer look at the folders and after all that time of moving files (maybe 100 albums) , all the folders beyond the first 30 or so were empty. So it looks like it created the folders for each artist and album but the songs have all vanished.
Help! Anybody else have this problem? And what did you do to fix?
Thanks!
Thanks!
