Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Golfdriver97
  • 1 Post By srkmagnus
    Default Help this mere mortal Oh Android Gods!
    I have a PanDigital White tablet which I think is running "SH20_20110302_K-PD_INX7E_ENG_6410POP" model no. PRD07T10WWH7..
    I want to install the newest version of Android it can handle. I don't care about losing any data or apps on the tablet.
    From what I've read I need to flash the ROM to do so. I hoping someone can give me non-geek instructions for the steps to take.
    Not worried about warranty since PanDigital is done.
    Help!!!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,729 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Help this mere mortal Oh Android Gods!
    Welcome to the forums.
    I did a little poking around, and found a site that claims a kind of sort of working version of CyanogenMod, but the thread was also littered with issues too.
    cm7.2 mostly working edition - now with moar audio - - Page 18 - Pandigital Novel Firmware / Development - SlateDroid.com
    rpw00d likes this.
    Golfdriver97,
    Thanks for looking but, I don't think that's what I want. Seems a little beta.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,694 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by rpw00d View Post
    Golfdriver97,
    Take a look at that source and see if there's a build more suitable to your needs. The Pan Digital device is probably not widely used by the development community, so it will not have wide support for this kind of thing.
    Golfdriver97 likes this.
  5. #5
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    CM7 is Gingerbread, so the chances are that no one is doing any more work on it. And, as srkmagnus said, the chances are that no one else is working on (or has worked on) a Gingerbread or higher ROM for the device. Since the company didn't issue any GB or higher ROM for it, I'm sorry to say that you're probably stuck with Eclair forever.
  1. New GS5 user - need major help!
    By globalexpresspilot in forum Samsung Galaxy S5
    Last Post: 07-04-2014, 03:01 PM
  2. Replies: 1
    Last Post: 04-24-2014, 05:38 AM
  3. No android 4.4 update
    By Jayson Jiang in forum Samsung Galaxy S4 Active
    Last Post: 04-22-2014, 05:58 AM
  4. Horrible battery life. Seeking help
    By Terz22 in forum Samsung Galaxy S3
    Last Post: 04-20-2014, 05:04 AM
  5. Large Battery Drain from Phone App and Android OS
    By Joseph Herbert in forum Samsung Galaxy Note 3
    Last Post: 04-18-2014, 09:29 PM
