Results 1 to 3 of 3
    Default lightning launcher- 2 widget questions
    hi all
    1-Is there a way to tell a folder to close once I click a widget (and not only app)?
    2- Is there a way to change an icon of a widget?
    (some widgets are really "only" apps)
    thanks
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: lightning launcher- 2 widget questions
    Quote Originally Posted by YossiN View Post
    If you mean to tell the phone to show a picture of a closed folder instead of an open folder, no. If you mean logically close the directory (which is what a folder icon represents), that's taken care of in the kernel and you have no control over it, but it's usually closed the moment the OS is finished using it.
    Yes. The normal way is to decompile the widget's apk file, change the icon picture file and recompile everything.
    All widgets are apps. I don't know what the "only" means - what else would you expect an app to be, other than an app?
    thank you VERY MUCH
    (practically, for all the questions you answered "no- this is not for novice like you :-) )
  1. weird question.... Anyone take a shower with their gear 2?
    By worldsoutro in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-21-2015, 01:36 PM
  2. Anyone try Solo launcher? I prefer it over Nova!
    By kingvanimal in forum Samsung Galaxy S5
    Last Post: 04-14-2015, 01:30 PM
  3. Replies: 1
    Last Post: 04-21-2014, 09:18 PM
  4. Replies: 2
    Last Post: 04-20-2014, 10:25 PM
  5. Question about Resetting Defaults
    By notedude3 in forum General News & Discussion
    Last Post: 04-20-2014, 04:21 PM
