1. dhinged's Avatar
    I'm testing a hybrid phone/scanner that came from China and I noticed the time was wrong on it (we don't use the phone part), so I went into time settings and it was set to automatic date & time and timezone, but when I turned off automatic timezone it said it was still China even though I've been using the device for a week. When I look up our IP on the web it says it's in the US in the correct state so I don't understand why Android is not locating the phone by IP.
    I've noticed on other Android phones the time randomly goes incorrect when off cell service (like on my old Droid 2 or Galaxy Tab which I keep the cell service off for), so this appears to be a bug in Android. Is there a way I can smack the phone so it does it automatically or do I always have to expect Google not to do this right and make me have to manually set the timezone (and sometimes the time)?
    04-22-2014 04:02 PM
  2. B. Diddy's Avatar
    Not sure what's up with that hybrid phone, but in general, Android requires a cell signal to determine your time zone--it can't use Wi-Fi or GPS to do this. This isn't really a bug--it's just how Android works. Time and date can be determined from the web, but you have to manually select your time zone if there is no cell signal.
    Posted via Android Central App--please excuse the brevity and any typos!
    04-22-2014 11:53 PM
  3. dhinged's Avatar
    Why can't Android determine my timezone from Wifi when when every website I go to on a computer (or the phone for that matter) can tell me my IP address and location? Can't a timezone be determined from a location? This seems like a major design flaw in Android, especially considering the Nexus 7 did not originally come with cell service and neither do some other popular Android devices (nor are they required to).
    04-24-2014 03:50 AM
  4. B. Diddy's Avatar
    You'd need to ask Android engineers about that.
    04-24-2014 11:17 AM
  5. jonifili's Avatar
    I have/had a similar problem with a Mobii P785 tablet (not gsm, just wifi) with android 4.4.2.
    After trying several options, I found out that it was the location services changing the time zone.
    So here are my options/solutions that worked for me.
    A) Use the GPS only option in locations services.
    B) Disable locations services all together.
    04-08-2015 11:35 AM
  1. Replies: 7
    Last Post: 04-28-2014, 02:41 PM
  2. Replies: 3
    Last Post: 04-25-2014, 11:21 AM
  3. Questions about video playback on the S5
    By beyondthesmile in forum Samsung Galaxy S5
    Last Post: 04-24-2014, 12:39 AM
  4. Can software be replaced on a dead Nesus 7?
    By dlhanna in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-23-2014, 07:15 AM
  5. Problem to install Custom Rom on Skyrocket
    By Alejandro Terry in forum Samsung Galaxy S II Skyrocket
    Last Post: 04-22-2014, 03:45 PM
