1. MTHall720's Avatar
    IN the last week my phone freezes within a few minutes of use. I mean no response at all to any taps, won't turn off even when pressing and holding the power button, nor will the power off menu appear. Then if I leave it on, within just a few minutes it overheats so badly it feels like I put it under a heat lamp. Tried everything I can think of with no results at all. This is the first time I have had any problems with this. I need the phone for work and some every elderly family members so I need it to work again. All is stock, with no tampering in any way at all.
    What do you recommend, besides taking it in to a Verizon store?
    Thanks much.
    04-22-2014 05:08 PM
  2. B. Diddy's Avatar
    A couple of things to try first:
    1. Check the battery. Remove it, place it flat on a table, and spin it. If it spins easily, it's bulging in the middle, which means it's going bad. Try a new battery.
    2. Remove the SD card (if present) and reboot. A corrupt card can cause various problems.
    If those solutions don't work, try wiping the cache partition. [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Posted via Android Central App--please excuse the brevity and any typos!
    04-22-2014 10:47 PM
  3. MTHall720's Avatar
    Thanks very much for the help.
    04-23-2014 08:40 AM
  1. Slow, Laggy S3.
    By FuzzieKiwi in forum Verizon Galaxy S III
    Last Post: 05-15-2014, 02:05 AM
  2. Help choosing a Phone.
    By HapyyGoku in forum General News & Discussion
    Last Post: 04-25-2014, 04:24 PM
  3. AT&T No-Contract vs. Unlocked
    By blackdogAC in forum HTC One M8
    Last Post: 04-24-2014, 11:19 AM
  4. Z2 and its amazing image stabilisation...
    By robsawalker in forum Sony Xperia Z2
    Last Post: 04-23-2014, 06:41 AM
  5. HTC One (M8) Turn off vibration for double tap?
    By mmmcheesedanish in forum HTC One M8
    Last Post: 04-22-2014, 03:28 PM
