Results 1 to 3 of 3
    zach2519's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Freezing/refusal to boot up issues with tablet
    I have a TMAX tablet on Jelly Bean, factory stock. Last night it froze and had to be reset with the button on the back of the tablet, after that when I tried to turn it on the start up menu displayed, but after that....nothing. No matter how long you waited it would never get past the boot up screen. After googling around I decided to factory reset it (with power + volume down since I couldn't get to Settings obviously), but the reset freezes as well. The farthest it advances is to wiping/formatting data, then it stops. I can turn it off and then back on and try it again, but it makes no difference, it doesn't get past wiping/formatting data.
    Any thing else I can try before I try to use the warranty for repair/a replacement?
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Default Re: Freezing/refusal to boot up issues with tablet
    It sounds like a hardware problem so unless you have replacement hardware (and are willing to void the warranty) I'd say no.
  3. #3
    Charmaine Malone's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Re: Freezing/refusal to boot up issues with tablet
    how do you shut down a galaxy tablet when freezing?
  1. Replies: 3
    Last Post: 05-28-2014, 11:03 PM
  2. lock button issues
    By duffkeekz in forum Verizon Galaxy S3
    Last Post: 05-02-2014, 08:58 PM
  3. Samsung S3 Verizo Phone keeps freezing, no tap response, and very hot.
    By MTHall720 in forum General Help and How To
    Last Post: 04-23-2014, 09:40 AM
  4. Is it possible to unlock a phone through another source other than the phone itself?
    By 23Hester in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-22-2014, 09:36 PM
  5. Disable confirm to delete email Stock Email
    By SERBDVB in forum Samsung Galaxy S5
    Last Post: 04-22-2014, 08:04 PM
