1. eekfu's Avatar
    Hi.
    I have a note 2, and the touch buttons next to the menu button responds late somtimes, or it wont work at all sometimes. What could be the prob?
    Normally it works fine, and my ram are under half when it happens so it is not ram. Also everything else works even tho the touch buttons don't.
    (sorry for my english).
    04-23-2014 03:57 AM
  2. Rukbat's Avatar
    First, Android normally runs with RAM as full as possible. Android isn't Windows. (RAM isn't storage, which has to have some empty space for Android to work properly.)
    Second, it could be a hardware problem or a software problem - there's no way to tell without actually testing the phone, so your best bet is to bring it to a repair shop and get a repair estimate.
    04-23-2014 05:57 PM
  3. eekfu's Avatar
    I found the problem..
    It was my screen protector
    Thanks anyways.
    04-25-2014 05:23 PM
  1. After KK update Power Button ends Call no matter selected or not
    By somenothingness in forum Verizon LG G2
    Last Post: 04-20-2015, 08:27 PM
  2. Remove files from S3 without using touch screen
    By tt7890 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-25-2014, 12:20 PM
  3. Replies: 2
    Last Post: 04-23-2014, 11:47 AM
  4. Samsung S3 Verizo Phone keeps freezing, no tap response, and very hot.
    By MTHall720 in forum General Help and How To
    Last Post: 04-23-2014, 08:40 AM
  5. Power Button and Ending Calls
    By FinalStar in forum General Help and How To
    Last Post: 04-22-2014, 08:00 PM
