Results 1 to 1 of 1
    MuziTao1126's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to use Android phone to play blu-ray movies of my pc?
    I have a lot of blu-ray movies on my pc.I am so lazy that sometimes i want to lie on my bed and use my phone to stream the movies. You know, there are some manners to stream normal films, but blu-ray movies is really difficult.
    Luckily I have found a solution to realize this and now i decided to share it with you.
    1.Install VidOn Server to your pc
    Download a software named VidOn Server to your pc and install it.
    2.Add the blu-ray movie folder
    Run VidOn Server -> Click Add in Media library-> Choose media type and path of the folder-> Click OK to complete the adding.
    3. Connect VidOn Player to VidOn Server
    Download VidOn Player to your mobile device
    Make sure your pc and mobile device in the same LAN
    Run VidOn Player-> Click to open VidOn Server-> Click the icon on the top right corner ->
    Choose the the right server-> Return.
    Then you will find the blu-ray movies of your pc are now on the phone.
    4. Enjoy Blu-ray movies
    Click the poster, you can see the detailed info of the blu-ray movie. Click Titles, you will see the easy blu-ray menu navigation. Click the play icon, the movie begin to play.
    While watching, you can choose the subtitles and audio tracks which you like. Then you can enjoy blu-ray movies on anywhere of your house by your phone. Its amazing, right?
  1. Replies: 5
    Last Post: 08-08-2014, 01:47 PM
  2. Anyone using/having problems with Chomp SMS?
    By ree3312 in forum HTC One M8
    Last Post: 06-08-2014, 11:46 PM
  3. Change backgroudn color of settings menu
    By meashishnd in forum Samsung Galaxy S3
    Last Post: 04-24-2014, 01:46 PM
  4. PLEASE Help flashing recovery to my GN3!!!
    By Steven Weatherbuzz in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-24-2014, 07:53 AM
  5. How to delete Message without confirmation?
    By jimbo1mcm in forum Verizon LG G2
    Last Post: 04-24-2014, 02:43 AM
