when i use my one widget i like from samsung, called "active applications", to clear out the ram, it says it has closed roughly 25 apps..... i only use maybe 4 on a regular basis... only have 6 of my own installed.
i recently (since i discovered i was rooted) downloaded app manager and used it to clear out all of AT&Ts obvious bloatware like "ashphalt 6" (since i used a rooted but stock ICS rom). but even with that its still such a high number. So, what the heck is running??
theres still a few apps i have to find out if i can delete like: at&t code scanner - may come in handy?, latitude, local, maps (ill probably never use, since i dont plan on ever using data - only wifi), media hub, memo, mini diary, navigation, play movies and tv (will youtube still work if i deleted this?), search (is that just the app for the google widget that i disabled right away?), talk, task, video player (does this allow you to play videos youve recorded on your own?), web (since i downloaded chrome, do i need web?)
Certain things since i dont know exactly what they do, i dont know if i can get rid of. Or, not sure if i can safely get rid of without messing anything up.
any help would be great!
