Results 1 to 3 of 3
    doni49's Avatar
    Posts
    Global Posts
    156 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Lightning Launcher. Some Icons have a line above them.
    I'm testing out Lightning Launcher on my SGS4 and so far, I really like what I see -- especially the ability to "pin" icons in a certain location.
    But I've noticed that some icons (not all) have a line above them for some reason. At first, I wanted to get rid of all the lines. But then I realized that I'd like to show them on some icons -- but I want to control which ones.
    I want to pin two rows of icons to create sort of a 2-row dock. And I'd like to have a line above the top row.
    Can someone help me figure out how to control this line?
    TIA!
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,764 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Lightning Launcher. Some Icons have a line above them.
    Have you checked through the Launcher settings to see if anything allows you to enable or disable that line? I don't use the launcher, so couldn't say what setting would control this (if you can) or why only some icons have the line. Could you post a screen shot so we can see which line(s) you are referring to?
    doni49's Avatar
    Posts
    Global Posts
    156 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    See the line above both the Chrome and All Apps icons? That's the line.
    I looked at every setting I could think of.
    Thanks.
    Sent from my SCH-I545 using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails Lightning Launcher.  Some Icons have a line above them.-1398520428118.jpg
  1. Bought these S5 replacement batteries and have been very pleased
    By scipio11111 in forum Samsung Galaxy S5 Accessories
    Last Post: 09-03-2014, 07:03 PM
  2. KitKat finally!! lets see them screen shots
    By Le_Roux in forum Samsung Galaxy Note 2
    Last Post: 05-07-2014, 12:58 PM
  3. Galaxy S4: New Icon on Notification Bar
    By HiddenPuppy in forum Verizon Samsung Galaxy S4
    Last Post: 04-27-2014, 02:12 PM
  4. 4.4.2 making some apps unusable?
    By Closingracer in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-26-2014, 08:36 PM
  5. Replies: 2
    Last Post: 04-26-2014, 02:29 AM
