Results 1 to 3 of 3
    Default Trouble Downloading E-mails
    Most functions of my new Galaxy S-4 work fine, but e-mails from both of my accounts fail to load reliably or promptly. I click on the recycle button under "combined inbox" or under each account's inbox, and it pauses for a second as if looking - and then nothing happens (even though I know there are e-mails still on the server). Much later, perhaps, the messages may be downloaded spontaneously.
    I know the account settings are correct because they load *sometimes*. I know the problem isn't with the servers because the e-mails load instantly to my computer. I know it's not due to my wireless or 4G network because I'm able to do other things on the phone. I thought the issue might be with the sync settings, but I've tried "manual" and "every 15 minutes," and it doesn't seem to make a difference.
    What can I do to make sure e-mail is pulled down right away, either manually or on its own? Thanks.
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: Trouble Downloading E-mails
    Make it "never". That sets it to Google Push Service. When the email arrives, it gets pushed to your phone. (If it's a Gmail account. For other accounts, the best bet is to use their email apps.) And make sure you have the account set to an IMAP account, not a POP3 account. (That's in the account's incoming server settings.)
    Thanks for your reply. I was hoping to use an e-mail client that combined messages from different accounts, as I do on my computers, rather than a separate app for each.
    Also, why would I change the phone's settings to IMAP if the actual accounts are POP3?
  1. Replies: 1
    Last Post: 02-22-2015, 07:43 AM
  2. voice mail notification indicator?
    By bertsirkin in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-27-2014, 04:03 PM
  3. Moto X: Evernote downloaded but not apparent
    By nyartist in forum Moto X (2013)
    Last Post: 04-27-2014, 06:38 AM
  4. best video downloading app w/playlist feature
    By zackscudder87 in forum Android Apps
    Last Post: 04-26-2014, 03:55 PM
  5. App download popup?
    By JKrischke in forum HTC One M8
    Last Post: 04-26-2014, 11:09 AM
