Results 1 to 4 of 4
    abhinit karna's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default android os using high background data in android 4.4.2
    Hello,
    I am using a MOTO X with android 4.4.2. The android OS has high background data usage only in cellular connection. There is no such issue in WIFI connection. I hav turned off auto backup, deleted Google+ and turned off all the syncs. Even after restricting background data the android os keeps using mobile data. I have done the factory reset once but even that didn't solve the problem. I hope you can help me with it.
    Thanks,
    Abhinit
  2. #2
    Rabbit_67's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: android os using high background data in android 4.4.2
    Hello,
    I have a Moto G and have noticed the same issue for about a week now.
    Previously I never had that kind of background data leak of the Android OS "app" in mobile data screen. (edit: i have of course enable "restrict background data").
    I recently started using Google Keep, Motorola Assist, and the Sleep app. Google Keep has its own icon in the mobile data menu and has only used 6.67KB, whereas "Android OS" is using up to 1MB per minute if I enable mobile data.
    Any clues?
    Edit: when I enable mobile data, it is to use the Dungeon Keeper (rubbish) app. Not sure if it's not related.
    Regards,
    JW
  3. #3
    Jordan Feero's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey, I also have this problem with my moto x. What I've been doing is just keep the mobile data on for a full day and just let it do whatever it's doing. I've made many calls to both Google and Motorola and neither can tell me why Android is gobbling all of my MBs.
  4. #4
    Kyle Mason1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am in this boat too. 430 some mb in a month on a Note 3.
  1. app data sync?
    By Justin967 in forum Android 4.4 KitKat
    Last Post: 06-16-2015, 01:39 AM
  2. Replies: 1
    Last Post: 07-13-2014, 04:40 AM
  3. Android security
    By Tai0406 in forum HTC One M8
    Last Post: 04-29-2014, 01:45 PM
  4. How can I find out when LTE was enabled in my area?
    By worldsoutro in forum T-Mobile
    Last Post: 04-29-2014, 12:58 PM
  5. using data
    By nonie in forum Samsung Galaxy S5
    Last Post: 04-28-2014, 10:45 PM
