Why do I need to periodically reboot Evo?
Fisherking
9
I've noticed that I periodically need to reboot my Evo, ie, turn it off and remove/reinstall battery. I've done this when the Evo doesn't perform as it's supposed to, e.g., when I can't see my text messages being typed in landscape or when I attach the Evo to the PC via USB cable but the dialogue box doesn't come up giving me the option to mount. Otherwise, I rarely power off the Evo (ie, its power on 24/7).
Does anyone else have this problem and is there something I can do to prevent the need to reboot, or is this simply a function of having a complex set of features? Thanks
dante501
104
7
I do have the same issue. I believe it is probably just of rooting it even shut down and reboot by it self. Didn't do it before rooting. I think it might be the overclocking and voltage change that makes it run kinda unstable but oh well its ok I guess. That's what u get for ****ing around with a few phone. Lol
takeshi
969
30
Difficult to say. You'd need to troubleshoot the matter. What's using your CPU? I've seen Watchdog recommended for this but have never used it myself.
Fisherking
9
Thanks, Takeshi. I'll check out Watchdog. Re CPU usage, I've added about 6 or 7 apps since buying the phone and the main ones I use are web browser, music, Slacker Radio, and MP3 Music Download. I periodically kill them via advanced task killer.
cloak.n.dagger
1,056
89
I know it's a sucky option but typically when these kinds of problems crop up, doing a factory restore fixes the problem. Just make sure to backup you contacts and sync with app brain so you can reinstall all your apps after words.
bclinger#IM
1,043
5
I reset mine every morning in order to keep the Bluetooth functionality functioning properly. Also, all electronic devices need a reboot/reset periodically. Factory restore/reset or whatever really takes care of it for a short period of time.
milominderbinde
2,163
1,179
I wish that there was an app that woudl reboot the phone every night at some certain time.
Even if your phone is working perfectly, a daily reboot keeps it at top speed..
bclinger#IM
1,043
5
It does. I do a nightly backup with Sprite Backup. In the WM release the device reboots after the backup is done. I will send a note to the developers requesting it.
