Results 1 to 8 of 8
    Default Allowing individual phone calls in Airplane Mode?
    Does anyone know of a way to allow certain phone calls to come through when your phone is in airplane mode? I would like to set my phone up so that in an emergency my husband and children can reach me even if my phone is in airplane mode.
    Deb from my Note 3
  2. Thread Author  Thread Author    #2
    Default Re: Allowing individual phone calls in Airplane Mode?
    Never mind I found an app that does what I need.
    Deb from my Note 3
  3. #3
    Which app did you use?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    It's called Audio Profiles. Nice enough that I purchased it
    Deb from my Note 3
    dpham00 likes this.
  5. #5
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    It's probably easier than the Tasker profile that lets someone get through if they call you 4 times in X minutes (or whatever numbers you want), while blocking people who don't know to do that. (Of course that's just one of the more trivial profiles that have been written for Tasker.)
  6. #6
    Quote Originally Posted by ShaggyKids View Post
    Deb from my Note 3
    If your in Airplane mode it turns off all cellular connection (no phone, no text, and no data).It turns off all "wireless connections", that means NO phones calls can come through. "NOTE - Airplane mode will deactivate the cellular signal, WIFI, and Bluetooth connections. WIFI can be manually enabled in Airplane mode."
    Quote Originally Posted by Rukbat View Post
    I wouldn't want to have to have people dial multiple times in order to get through this.
    Deb from my Note 3
  8. #8
    How about try to go under settings--> my device--> Blocking mode --> turn on the mode --> Allow contacts--> choose custom --> then only select the number you'd like.
    You can either customise it to happen daily or turn it on & off when is required.
  1. Stuck in landscape mode after watching movie.
    By heavyvino in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-31-2015, 01:44 PM
  2. Weird bug in HTC email app
    By quanitc in forum HTC One M8
    Last Post: 04-29-2014, 03:54 PM
  3. Did KitKat screw up my phone?
    By irategamer in forum Android 4.4 KitKat
    Last Post: 04-29-2014, 10:46 AM
  4. Stuck in Android System Recovery (3e)
    By jaaf in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-29-2014, 10:30 AM
  5. SmartAction/Airplane Mode
    By 5111 in forum Samsung Galaxy S5
    Last Post: 04-29-2014, 09:57 AM
