1. androiduserfan's Avatar
    Hello,
    i just bought an HTC One Mini on eBay.
    The smartphone seem to be of Orange.uk (i saw this info using cpu-z app) and does not contain all languages (for example italian, and since i'm italian this isn't a good news).
    I'm using this smartphone with a SIM of course not of Orange so i think that is unlocked.
    But i want to flash a "classic" Stock of HTC One Mini European, not this. The actual ROM also is "locked" to Android 4.3 and if i check updates he don't find nothing.
    So how can i flash a stock european rom? And where i can find it?
    #Little update
    I've just found the Stock european here (or is somethings else?) htcdev.com/devcenter/downloads/
    but now how i can flash it?
    04-30-2014 08:36 AM
  2. wizzrah's Avatar
    Hello,
    #Little update
    You probably found an RUU. You don't want to flash a wrong RUU. You are probably going to have to flash a custom ROM.
    04-30-2014 05:08 PM
  1. Unable to save file to SD card???
    By ansa82 in forum Verizon Samsung Galaxy Note 3
    Last Post: 08-02-2016, 04:34 AM
  2. Best Way to Prepare for KitKat?
    By ShaggyKids in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-04-2014, 07:36 PM
  3. how to install ota updates on rooted galaxy s2 plus
    By Amir Sherif in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-02-2014, 12:09 PM
  4. Frustration with Battery Cover on Galaxy S5
    By Jon Jackson in forum Samsung Galaxy S5
    Last Post: 05-01-2014, 12:05 AM
  5. switching back to the factory sms app
    By Justin Stepp in forum HTC One M8
    Last Post: 04-30-2014, 10:20 AM
