Results 1 to 4 of 4
    Default Good phone case cleaner?
    Looking for suggestions for good products to clean my phone case. I believe mine is vinyl. I would prefer to use something that won't dry it out or make it greasy.
    Deb from my Note 3
  2. Best Answer
    If it's vinyl, any good vinyl cleaner/conditioner will work well on it. Look where pocketbooks or other small (not swimming pool liner size) vinyl items are sold. Even the larger stores like Sears, Penny's, etc., may carry some product they recommend. (The conditioner part is what will keep it from drying out - a cleaner without a conditioner will cause it to crack eventually. But it's always going to feel a bit slippery unless it's pebble-grained, in which case even if you rub oil on it, it won't feel greasy. Smooth vinyl just has that "there's something slippery on it" feel to it. Especially when it's new, since some of the elasticizers are still coming out of the material, keeping it wet and oily even if you use an oil-removing cleaner on it. You clean it off and more comes out. It can take 6 months to a year for fresh vinyl to stop "sweating".)
  3. #2
    Gekko's Avatar
    Banned
    Posts
    Default Re: Good phone case cleaner?
    this is good to clean the phone display and the case. make sure you do not spray directly onto the display - always spray the microfiber cloth. free refills at the store too.
    SUNGLASS HUT
    CARE KIT
    Sunglass Hut CARE KIT Accessories | Sunglass Hut
    ShaggyKids likes this.
  4. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
  5. Thread Author  Thread Author    #4
    I should be okay then because my case is not smooth its got texture to it.
    Deb from my Note 3
  1. MLT apk disable or remove on LG phones
    By dctokyo in forum LG G2
    Last Post: 05-02-2016, 12:45 AM
  2. Phone saying it's charging when it is not plugged in
    By thehappiestone in forum Samsung Galaxy S3 Mini
    Last Post: 05-11-2014, 08:13 PM
  3. need help finding a case
    By geoffwhite18 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 05-03-2014, 12:03 PM
  4. Replies: 0
    Last Post: 04-30-2014, 10:50 AM
  5. If current phones already have hardon..
    By ChrisGonzales90 in forum HTC One M8
    Last Post: 04-30-2014, 01:31 AM
