Results 1 to 9 of 9
    Default 4G no longer dims when Wifi connects
    Samsung Galaxy S5 Android 4.4.2
    This is quite odd. My mobile data (4G LTE) symbol in the header area used to dim (like when you disable mobile) when my Wifi kicked in and it does not anymore.
    So it always appears that both 4G and Wifi are active at the same time. Only after watching which up/down arrows are flickering do I know which is working.
    And on some occasions, the arrows on both flicker. I am not 100% sure, but I think this started after I turned on the Ultra Power Savings mode.
    Can anything be done to resolve this?
  2. #2
    Murph5150's Avatar
    Posts
    Carrier
    Euroskank CM10
    Default
    Quote Originally Posted by bearcatflex View Post
    I have the Galaxy S4, and since I updated to KitKat, my 4G/3G icon don't disappear when I activate Wi-Fi. I've mentioned this in other forums and many others are experiencing the same thing. I went into my settings with Wi-Fi on and 4G showing, and it said I was off the mobile network. The S5 may be different, but access your settings under "about pbone" I believe, and see if your phone is using Wi-Fi data or 4G data. So even though it is deceiving, you likely aren't using allocated data when you are connected to Wi-Fi. But it doesn't hurt to check. Hope that helps.
    Default Re: 4G no longer dims when Wifi connects
    Which settings were you looking in to verify this?
    I guess I am just confused as it was working fine just yesterday.
    Has anyone mentioned a factory reset? I don't have much on the phone yet so I might give it a go.
  4. #4
    Murph5150's Avatar
    Posts
    Carrier
    Euroskank CM10
    Go to settings - > more - > about phone - > status - > mobile network state - it should say "disconnected" If Wi-Fi is enabled. That will validate your question.
  5. #5
    Murph5150's Avatar
    Posts
    Carrier
    Euroskank CM10
    A factory reset won't change anything. It is a design characteristic of Android 4.4.2.
    Still says connected even though WIFI is on and the arrows are flickering.
    I turned off mobile data, and it stills says connected. And I kept it off, restarted the phone and it still says connected.
  7. #7
    Murph5150's Avatar
    Posts
    Carrier
    Euroskank CM10
    Interesting. I figured the similarities between the S4 and S5 would be close enough where the directions I gave you would state that mobile data is disconnected. Two suggestions - Repost this question on a dedicated Galaxy S5 forum here on Android Central or get in touch with Verizon tech support. You'll probably find a faster answer on the forums and I can't say I've ever had a great experience with Verizon tech support. Other S5 owners on this forum are usually knowledgeable and can address and possibly resolve your issue. Sorry my suggestion didn't work.
    Good luck!
    Sent from my SCH-I545 using AC Forums mobile app
  8. Thread Author  Thread Author    #8
    Totally just figured this out. I am Verizon customer.
    It's the Caller Name ID app. Immediately after disabling it, the 4G symbol dimmed as normal.
    And thank you for the suggestions. Nice to see the community is active and responsive.
  9. #9
    Murph5150's Avatar
    Posts
    Carrier
    Euroskank CM10
    Nice detective work! I wouldn't have thought of that. Glad you were able to figure it out.
  1. Galaxy Note Pro 12.2 - VPN connected but no application able to connect.
    By Adoga in forum Samsung Galaxy Note Pro 12.2
    Last Post: 03-05-2015, 12:49 PM
  2. Can't get into recovery, no ROM installed, odin won't work
    By jrc058 in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 05-02-2014, 10:54 PM
  3. Gear 2 Neo loses BT connection
    By nklv_aleksa in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-01-2014, 11:59 AM
  4. Replies: 0
    Last Post: 04-30-2014, 07:04 PM
  5. When Gear Connected Can't Hear Viber Voice message
    By Nika Lomtadze in forum Samsung Galaxy Gear
    Last Post: 04-30-2014, 05:31 PM
