1. Owais Awan's Avatar
    Hello All
    I am new at rooting and installing custom ROMS at android.
    I tried to root my android mobile (Qmobile A-900, which is a rebranded version of Gionee Elife E3 Specs and Data sheet) from here and was sucessful.
    I installed "MTK mobileuncle" app from google play store which would reboot phone to CWM Recovery when i select "recovery update" option.
    Next i tried to install a custom Rom and followed each and every step mentioned here
    "For CWM Recovery i follwed steps mentioned here"
    I made by current stock ROM backup file into SD saved in path SDCARD\clockworkmod\backup
    Then in CWM recovery mode i selected Format data/factory reset , then Install from ZIP, Select the Downloaded Zip (selected the custom ROM zip which was 383 Mb, the screen then installed and i recieved "sucessfully installed message while in cwm which then said that i should Reboot my phone which i did.
    But now i just get my old Stock Rom welcome logo when i boot my phone for 3 sec and then it restarts and the same thing happens again and again.
    Please help me if there is any way to solve this problem. "I know its not bricked coz it still displays stock rom logo and starts for a while."
    Thanks in advance
    03322201309 likes this.
    05-01-2014 07:13 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    I would force a reboot into recvoery, restore your backup so you can at least get back up and running.
    Then I would redownload the file, and try again.
    05-01-2014 08:24 AM
  3. Owais Awan's Avatar
    Hello there and thankyou for the reply.
    Can u please guide me with the steps i am super new at this. i googled force reboot intro recovery and found nothing useful. If i hold down both Vol + - buttons with power button the mobile just starts up with company logo which shows and disappears after 3 sec and then it restarts again and again in the same manner
    05-01-2014 08:39 AM
  4. Golfdriver97's Avatar
    Is there any way you can reflash the stock ROM?
    Sent from my HTC One_M8 using AC Forums mobile app
    05-01-2014 10:52 AM
  5. Owais Awan's Avatar
    I can reflash stock rom as i have the backup but i cant open the boot screen using the three button combo. is there a way directly from pc?
    05-01-2014 11:24 AM
  6. Golfdriver97's Avatar
    Sorry, I keep forgetting you have a hard time staying in recovery without it rebooting. In this case, I am not sure what to suggest.
    05-01-2014 01:47 PM
  7. 03322201309's Avatar
    unfortunately keyboard has stopped
    10-23-2015 03:26 AM
  8. Golfdriver97's Avatar
    Welcome to the forums. Can you install another keyboard via Google Play on Desktop?
    10-23-2015 09:08 AM
  1. Waking up phone.
    By byeblackberry in forum Samsung Galaxy S5
    Last Post: 05-03-2014, 03:25 PM
  2. After Text Mess Sound
    By oil64 in forum LG G2
    Last Post: 05-01-2014, 04:09 AM
  3. Replies: 2
    Last Post: 05-01-2014, 01:50 AM
  4. Replies: 0
    Last Post: 05-01-2014, 01:03 AM
  5. How to install apps on Carbon ROM?
    By FutureMarine in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 04-30-2014, 10:03 PM
