1. Sad SouL's Avatar
    Hello
    i'v bought galaxy s4 19505 from ebay.uk
    it's uk version and i live in egypt
    sticker at the box says
    european sim model
    i had changed the android version and it worked in my country
    but the wi fi not work
    note :
    ( wifi icon give green light but not like it should to be )
    about device info
    model number gt-19505
    android version 4.3
    baseband version 19505xxuemj5
    kernal version 3.4.0- 1869009
    build number jss15j.19505xxuemj5
    secure boot status type samsung
    United Arab Emirates
    this message appear befor wifi stopped
    The device has detected an application attempting to perform actions that are not permitted. These actions have been blocked.
    What should i do to make wifi work at my phone ?
    05-01-2014 09:13 PM
  2. Kelly Burby's Avatar
    Hello
    european sim model
    note :
    about device info
    android version 4.3
    Have you tired restarting your device or you can also try doing a soft reset, I think there is some problem with the settings or may be the ROM isn't initialised correctly. I would say either try doing a soft reset or try doing a full hard reset.
    05-02-2014 01:42 AM
  3. Sad SouL's Avatar
    can you please tell me which rom i should install and will work correct with my device
    05-02-2014 03:14 PM
  4. Sad SouL's Avatar
    still have the problem
    05-05-2014 08:00 PM
  5. Sad SouL's Avatar
    what i can do
    05-07-2014 10:37 AM
  6. Sad SouL's Avatar
    no one know how to fix this ?
    05-14-2014 09:10 AM
  1. Replies: 9
    Last Post: 06-13-2016, 07:55 PM
  2. android.process.media killing my battery
    By dgprakash in forum Samsung Galaxy Note 3
    Last Post: 06-15-2014, 12:59 PM
  3. How can I transfer pix from the phone to iPhoto?
    By mark1wis in forum Verizon Droid Charge
    Last Post: 05-03-2014, 01:26 AM
  4. Copying files problem
    By quarrymanpaul in forum HTC One M8
    Last Post: 05-02-2014, 12:23 PM
  5. Problem with Facebook "recent" posts?
    By LisaLee660 in forum Samsung Galaxy S5
    Last Post: 05-02-2014, 12:41 AM
