1. Zephrix's Avatar
    Hello everyone, this is my first post.
    So what happened is, I was holding my phone and wanted to wash my hands, so I placed my Samsung S2 next to the sink (I was pretty dumb, I should've put it inside my pocket instead. ) , and while washing my hands, the water jumped and hit my phone and my phone was about to die (1% Battery) and it died at the same time.
    But my phone went to Factory Mode, you know that things like, "Factory Mode" and stuff "Don't turn off", so I didn't turn it off and waited, after that, the phone died. I tried turning it on and didn't work and so I thought, "Why am I testing it when it died?", so I tried to charge it, the phone went to the "Samsung Galaxy" thingy like the very first thing to see when you just turned it on, but then after a while, it died again, then it does it again, just repeating. I tried using a USB cable and it did the same.
    What do I do? Please help me! I'm panicking right now.
    05-02-2014 10:07 AM
  2. mobilecrackers's Avatar
    Do not turn on your phone when it is wet
    for safety
    keep your phone inside sack of rice overnight
    05-02-2014 10:48 AM
  3. ShaggyKids's Avatar
    Try charging it for several hours and see if that helps. You can Google for how to dry out your phone. There's a technique for putting it in a bowl full of dry rice but I don't know what the entire process entails. If you open the Phone or leave it as is I don't know or for how long. I doubt splashing a little water on it would have a bad effect not like submerging it prolly would! But I could be wrong. Good luck!
    Your battery may also be bad.
    Deb from my Note 3
    05-02-2014 10:52 AM
  4. Golfdriver97's Avatar
    Welcome to the forums.
    for safety
    Sound advice to follow.
    05-02-2014 11:03 AM
  1. Moto G Google Now Launcher.
    By jeanlucpicard22 in forum Android 4.4 KitKat
    Last Post: 08-09-2014, 06:21 PM
  2. Replies: 13
    Last Post: 05-03-2014, 10:43 AM
  3. update and rooted
    By binghjs78 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 05-02-2014, 06:18 PM
  4. Will update get rid of my data?
    By Aussrh420 in forum Samsung Galaxy S4
    Last Post: 05-02-2014, 10:15 AM
  5. Sync My Calendar/Google Calendar/Outlook, no ActiveSync or Google Apps
    By mamasamaki in forum Samsung Galaxy SIII I9300
    Last Post: 05-02-2014, 10:04 AM
