1. ahawkua's Avatar
    I've tried to save my sd card multiple ways but haven't had any luck. Ive even tried putting it in my camera and got an error. What should I do?
    05-02-2014 11:59 AM
  2. mobilecrackers's Avatar
    try formating the sd card from your phone if it dosnt help format with pc
    05-02-2014 12:12 PM
  3. B. Diddy's Avatar
    Are you trying to save the data on there, or just trying to make it usable? SD cards can fail, either due to age or defect, so it may just be lost.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    05-02-2014 12:45 PM
  4. ahawkua's Avatar
    I've tried formatting it on both my phone and PC. Even used programs recommended on XDA developers site
    05-02-2014 09:22 PM
  5. mobilecrackers's Avatar
    May be you sd card os damaged
    change the format type to FAT
    Sent from my GT-N7100 using AC Forums mobile app
    05-03-2014 03:55 AM
  6. ahawkua's Avatar
    What's that mean?
    05-03-2014 05:30 AM
  7. mobilecrackers's Avatar
    when you format a pendrive from pc it will ask different type of formatting options like FAT , FAT32, etc check that out now...
    05-03-2014 05:39 AM
  8. ahawkua's Avatar
    Well I've tried formatting it in various ways on my computer. It doesn't even tell me the capacity of the SD card or anything. It shows the drive letter. But I've even tried doing the chkdsk command and it said it doesn't have direct access to the drive. I'm sort of thinking it's a goner.
    05-03-2014 01:12 PM
  9. mobilecrackers's Avatar
    The sd card might have been damaged
    05-03-2014 11:35 PM
  10. ahawkua's Avatar
    I'll probably get another one. I'm not sure how it got damage though.
    05-04-2014 12:53 PM
  1. S3 won't charge - Battery Temperature Too High!
    By JoshR81 in forum Samsung Galaxy S3
    Last Post: 05-05-2014, 10:14 PM
  2. my M8 experience
    By kaide Le Blanc in forum HTC One M8
    Last Post: 05-02-2014, 03:09 PM
  3. Dirt on camera
    By Lucas Stollmeier in forum Samsung Galaxy SIII I9300
    Last Post: 05-02-2014, 02:11 PM
  4. Replies: 6
    Last Post: 05-02-2014, 12:36 PM
  5. my new FREE PRANK APP - measure *****
    By Zjajo in forum Android App Inventor
    Last Post: 05-02-2014, 10:43 AM
