View Poll Results: Do you have wakelock problem on nexus 5, kitkat or any other device?
Voters
4. You may not vote on this poll
  • YES HTC
    0 0%
  • YES LG
    0 0%
  • YES APPLE
    0 0%
  • YES SAMSUNG
    1 25.00%
  • YES KITKAT
    0 0%
  • YES NEXUS , NEXUS S, NEXUS 5
    1 25.00%
  • NO
    2 50.00%
Multiple Choice Poll.
Results 1 to 19 of 19
Like Tree5Likes
  • 1 Post By Golfdriver97
  • 2 Post By Golfdriver97
  • 2 Post By B. Diddy
  • 1 Post By _pp
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Neep urgent help.. Battery draining because of a wakelock
    Hello everyone. So as the title suggests my nexus 5's battery is draining due to something. I've been using the device for a couple of months now, and it was all fine till one week ago. I used to get a good one day battery timing with about 4 hours of screen time. Now all of a sudden my battery is draining like anything. I believe that it is due to a wakelock as andriodOS and Andriod system, are likely on top of my battery usage. I previously installed GSAM battery monitor pro and under wakelocks, it shows alarm at the top. I have no alarms on, and I have tried deleting my google keep reminders. Still, the battery is draining.
    Right now I am having 15% battery remaining after 12h 13m 25s
    here are the complete details:
    Android OS 72%
    Andriod System 8%
    Screen 8%
    phone idle 3% at 11h 1m 14s
    I would really appreciate help as this is making me not being able to use my phone normally. Also the phone keeps hot most of the time. I was also using DS battery saver pro which helped me get the above stats as it drains even more quickly without it.
    Any help would be really appreciated.
    Nexus 5 Stock Android 4.4.2
    Thanks!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Neep urgent help.. Battery draining because of a wakelock
    Can you provide a screenshot of the battery stats? Include the list of the apps and the graph as well please.
    B. Diddy likes this.
  3. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    77,765 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Does this behavior persist after a reboot?
    Posted via Android Central App--please excuse the brevity and any typos!
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    Yes, sure.
    Attached Thumbnails Attached Thumbnails Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-09-05-42.jpg   Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-09-05-51.jpg   Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-10-00-19.jpg   Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-10-00-42.jpg
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    Yes tried that as well. The problem once got solved itself for one day, and everything became normal, but the next day the problem came back.
  6. #6
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by _pp View Post
    Try rebooting into recovery, and clear the system cache. Here is how: [GUIDE] Nexus 5 Recovery
    Sent from my HTC One_M8 using AC Forums mobile app
    B. Diddy and _pp like this.
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is it risky or can it damage my phone. Also has it before solved any problem like this? I mean like are u sure I should try this?
  8. #8
    B. Diddy's Avatar
    Posts
    Global Posts
    77,765 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Clearing the cache partition will not erase any personal data nor will it damage anything. It can correct a number of fairly nonspecific issues, so it's worth a try.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    Golfdriver97 and _pp like this.
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'll just let my phone charge and try clearing the cache. Will I know if it hopefully works
  10. Thread Author  Thread Author    #10
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I tried clearing the cache partition, but there's still no significant difference in battery drain. Its draining at the same rate. About 3 percent in about 15 minutes of no use, with only wifi turned on.
    As in one of the screenshots, the alarm comes at the top of kernel wakelocks. So any way to get the exact app which is causing the phone to stay awake?
  11. Thread Author  Thread Author    #11
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Alarm wakelock down but another up. Will update after using it for some time
    Attached Thumbnails Attached Thumbnails Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-12-58-49.jpg
  12. Thread Author  Thread Author    #12
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Neep urgent help.. Battery draining because of a wakelock
    Battery not draining anymore .. Phone not getting hoy anymore, at least not that quick. Phone used to stay 40c most of time, now its 35C almost at rest. No more worries about wakelocks anymore I hope.!
    Thanks to both of you for helping me get out of this trouble .. Any suggestions not to encounter it again?
    And now there's this another wake lock. Although it's not draining my battery too much to notice, but still I would want to get rid of it. I think its normal but I would like to be clarified of it is normal or not!
    Attached Thumbnails Attached Thumbnails Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-15-59-23.jpg   Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-15-59-35.jpg   Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-16-02-21.jpg   Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-16-17-35.jpg
  13. #13
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    It is so hard to say what the cause was. I typically clear cached data on my devices once a month. Some might say that is overkill, but I am used to doing it and it helps keep my devices snappy.
  14. Thread Author  Thread Author    #14
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anyhow, it worked and device is back to normal. Hopefully this forum will help other people as well.
    Just a screenshot! Thanks again!
    Attached Thumbnails Attached Thumbnails Neep urgent help.. Battery draining because of a wakelock-screenshot_2014-05-03-18-57-25.jpg
    Golfdriver97 likes this.
  15. #15
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Glad it helped. See you around the forums.
    _pp likes this.
  16. Thread Author  Thread Author    #16
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Should I change the runtime to ART?
  17. #17
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    You don't have to. I run ART.
  18. Thread Author  Thread Author    #18
    _pp
    _pp is offline
    _pp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any visible changes you felt? Also is the battery better on RUN as compared to Dalvik?
  19. #19
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ART is a different way to run apps that is note efficient.
  1. Getting rid of the white dot that pops up where you touch screen
    By PsychDoc in forum Verizon Galaxy Note 2
    Last Post: 12-15-2016, 09:51 PM
  2. samsung galaxy not working with straight talk,Help
    By Mike Weidman in forum AT&T Galaxy S3
    Last Post: 05-10-2014, 06:28 PM
  3. Replies: 3
    Last Post: 05-03-2014, 06:32 PM
  4. Has anyone broken the 3 day mark with the battery?
    By thepurpleturtle in forum HTC One M8
    Last Post: 05-03-2014, 02:17 PM
  5. galaxy s4 root help plz!!
    By XxRsawy8 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 05-03-2014, 10:13 AM
