Results 1 to 2 of 2
    Default Help with CWM 6.0.4.8 partition sd card?
    Trying to partition my sd card... but im not seeing that option in the recovery menu at all. from what ive read it should in advanced.
    but all i see is reboot, reboot to bootloader, power off, wipe dalvik cache, report error, key test, and show log.
    nothing about SD cards at all.
    tried the option within the actual app with the tablet running... didnt seem to actually do anything as link2sd, which im trying to get to work, still will not work.
    help?
    im running a samsung galaxy tab 3 i believe its t210r (not my own, trying to fix it up and speed it up for a friend).
  2. #2
    Default Re: Help with CWM 6.0.4.8 partition sd card?
    same problem here mate. Did u find any solution to it..?
  1. So close to top 20, a li'l help?
    By Ryan Jorgenson in forum Android Games
    Last Post: 02-22-2015, 07:37 AM
  2. ZTE Unico LTE SD card apps shortcuts
    By psdnakita in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-08-2014, 12:47 PM
  3. Replies: 3
    Last Post: 05-03-2014, 06:32 PM
  4. Neep urgent help.. Battery draining because of a wakelock
    By _pp in forum General Help and How To
    Last Post: 05-03-2014, 01:00 PM
  5. Replies: 0
    Last Post: 05-03-2014, 01:33 AM
