1. petvas72's Avatar
    Hi,
    I have a question about how I can reset the default app settings. For example, using Blinkfeed on my M8, when I tap on a link, the first time I was asked which browser should be used. How can I reset Blinkfeed, or any other app to ask me again which app to use? Is it always an app setting, or can I centrally control that behavior?
    05-03-2014 02:22 PM
  2. Golfdriver97's Avatar
    Hi,
    Its in settings>apps>swipe over to all apps, then scroll down to the app in question. Click on it, and you can click clear defaults.
    You can also reset all of them by settings>apps>menu>reset app preferences.
  3. Golfdriver97's Avatar
    Hi,
    petvas72 likes this.
    05-03-2014 02:31 PM
  4. petvas72's Avatar
    Thanks! That is exactly what I was looking for.
    05-03-2014 02:35 PM
  5. Golfdriver97's Avatar
    No sweat. See you around the forums.
    05-03-2014 04:38 PM
  1. How do I reset my auto correct?
    By JustinJK in forum Samsung Galaxy Note 3
    Last Post: 02-07-2016, 07:17 PM
  2. [App] Christian and Catholic music [Android]
    By zarggot in forum Android Games
    Last Post: 02-22-2015, 06:37 AM
  3. Replies: 14
    Last Post: 05-14-2014, 07:08 PM
  4. [APP][FREE][1.6+] Status Message (+ Love Status)
    By tech_worm in forum Android App Inventor
    Last Post: 05-13-2014, 03:24 AM
  5. S5 Video Settings defaulting
    By lonechicken in forum Samsung Galaxy S5
    Last Post: 05-03-2014, 07:08 AM
