I picked up a Samsung Galaxy Tab 3 8.0 last week and until now Ive only used it on my wifi network at home, which was quick and easy to connect to. Tonight I brought the tablet to work and tried to connect to the wifi here, and at first it would say it was connected and then the screen for me to enter my username and password for the network here at work would show up as normal, I'd type in my username and password (correctly!) and hit submit and all it would do was refresh that same page and ask me to enter my username and password again. After a couple attempts, I hit forget network and restarted the tablet hoping that would fix the problem, but it only made things worse. Now when I go to connect to the network, it says it's connecting..., then says "saved", but it actually never ever does connect and I can't even get the login screen to come up anymore. Anyone have any ideas?? I can use my iphone to connect to the network flawlessly, so I'm assuming it's an issue with my tablet??
Thanks!!
Thanks!!
