1. mitchreward's Avatar
    Hi guys,
    Sorry if it's a known issue, but I did some research and I didn't find anything.
    I have a HTC one SV , which once connected in MTP to my computer will not let me access the contents of the external sd-card. Not really confortable to put and retrieve Music and photos.
    When I connect it it's mounting on my pc with 2 directories inside :
    -> internal memory
    - > sdcard But which is actually , the internal phone storage
    /the sdcard works properly and is mounted in the phone file system as sdcard2/. But no sdcard2 or something like that (for the real SD).
    Is this due to a recent update or something?
    As I have no SD card read on my laptop , now to recover the photos, I must:
    create an FTP server, connect to it with the aid of a file manager app to put photos on my computer ... slightly painful in 2014
    An idea , any advice to debug? Thank you in advance
    05-04-2014 05:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I would suggest buying a USB plugin SD card reader for your laptop, which should be pretty inexpensive. Then you can unmount and remove your SD from the phone and insert it into the card reader on the laptop.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    05-05-2014 01:15 AM
  3. mitchreward's Avatar
    yeah but I'd like to find out why this does not work anymore. this is annoying. Anybody suggest something else than buying a sdcard reader ?
    05-05-2014 12:57 PM
  1. Problems sending MMS from Galaxy S4 to iPhone
    By Brian Pierson in forum Samsung Galaxy S4
    Last Post: 11-04-2014, 09:55 PM
  2. Replies: 6
    Last Post: 09-03-2014, 03:23 AM
  3. Distortion/crackling from ear piece speaker - is this normal?
    By AndriodAK in forum Samsung Galaxy S5
    Last Post: 05-13-2014, 02:59 PM
  4. SD Card
    By amazondrone in forum Verizon Samsung Galaxy S4
    Last Post: 05-06-2014, 12:19 PM
  5. Help wifi issues
    By allen silfies in forum Samsung Galaxy S4
    Last Post: 05-05-2014, 03:34 AM
