HELP! Dropped my HTC One X and it wont turn on now?!
Ttyler_0
I have dropped this phone before (clumsy me) and it cracked the screen but the phone itself continued to work completely fine for an entire year. Yesterday, It fell out of my hand again and fell screen down on the floor of my bedroom. The screen wont turn on now. The home buttons light up, and the red light still comes on when I plug it in to charge, but the screen itself remains Black...
Is there anything I can do to try and fix this? or is that it?
Welcome to the forums.
The fall probably damaged the digitizer or some other hardware component. You can look into fixing it, but it may not be very cost effective as the part may be difficult to find, and often when replacing the screen, other parts tend to get damaged as a result.
If you have an upgrade that you can use, I would use it.
Welcome to Android Central, and I agree with Golfdriver97. Are you eligible for an upgrade? Sounds like a good excuse to get a shiny new phone!
Posted via Android Central App--please excuse the brevity and any typos!
Wrapcart
