1. Phil_SCS's Avatar
    My Galaxy S3 (have had it 15 months) was playing up, when about 50-60% battery remaining the screen would go fuzzy and flicker then the phone would reboot and come back with between 1-8% battery left then switch off pretty quick.
    Did all the usual checks for what might be draining it but to no avail.
    Found this on another thread and it seems to have fixed the problem it may work on other Samsung or Galaxy models and does not lose you any information. It was recommended by the Samsung help-line.
    Turn it off.
    Leave it 10 seconds
    Press and hold the volume up button
    Press and hold the Home button
    Then press and hold the power button.
    When the phone powers on, let go of the power button only.
    When you see a screen with "Android system recovery" let go of the other 2 buttons.
    Using the volume down button, scroll to "wipe cache partition" then press the power button.
    When the menu comes back, press the power button when "reboot system now" is highlighted.
    And there you go, everything is still there and my battery doesn't play up any more.......
    They say you should do this before you do any Android updates. Let me know if it works for you and what model of phone you did it on.
    B. Diddy likes this.
    05-05-2014 01:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central, and thanks for your post! For future reference, here's a detailed thread about the same process: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Posted via Android Central App--please excuse the brevity and any typos!
    05-05-2014 03:14 PM
  1. Galaxy S4 GT-I9500 Repair IMEI "NULL/NULL"
    By eriktuz in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-15-2015, 09:22 AM
  2. Battery issues
    By pratnala in forum Google Nexus 5
    Last Post: 05-13-2014, 12:19 PM
  3. Back Camera Lense broken Galaxy S5
    By Barqueen in forum Samsung Galaxy S5
    Last Post: 05-08-2014, 03:54 PM
  4. Getting rid of Hangouts on S3
    By Rick Bell in forum Verizon Galaxy S III
    Last Post: 05-08-2014, 01:43 PM
  5. Battery heating up?
    By psychspirit in forum Samsung Galaxy S5
    Last Post: 05-05-2014, 04:57 PM
