1. mfl's Avatar
    Hello guys,
    i'm new on this forum and i need your help. My touch screen doesnt work and i need to enter on my android to take my pictures back. I have no SD Card, they are all in the internal memory of the phone. Its possible?
    I tried Kies but the phone is locked by a security code.
    Thanks
    05-05-2014 07:03 PM
  2. mobilecrackers's Avatar
    Hello guys,
    Thanks
    Go to recovery then clear cache
    what security code, block you from accessing KIEs
    05-05-2014 08:13 PM
  3. mfl's Avatar
    Sorry, but could you explain me a little bit more?
    I didn't quite understand how I clear cache with a broken toucscreen
    05-06-2014 04:33 AM
  4. mobilecrackers's Avatar
    sorry my mistake
    your touch screen is fully damaged, you can't even unlock the security ..
    but you can go to recovery, recovery doesn't need any touch . you can use the up and down keys to access the recovery
    form there clear cache and data
    if you can' t even use the screen then better take it to Samsung service centre
    05-06-2014 04:51 AM
  5. cararochelle12's Avatar
    Maby use the volume and home buttons x
    Sent from my iPod touch using Tapatalk
    06-27-2014 01:26 AM
  1. how to check internal memory size, 16, 32 or 64Gb?
    By David Portabella in forum Samsung Galaxy S4
    Last Post: 02-07-2016, 04:02 PM
  2. How does the Droid Maxx compare to the older Razr Maxx
    By bluwtr49 in forum Motorola Droid MAXX
    Last Post: 05-18-2014, 11:08 PM
  3. S3 to S4 - Titanium Backup restore
    By zetodavido in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 05-14-2014, 12:28 AM
  4. Now my music and photos are acting weird on my Kyocera Event
    By zeiriza12 in forum General Help and How To
    Last Post: 05-05-2014, 07:01 PM
  5. Replies: 0
    Last Post: 05-05-2014, 06:30 PM
