1. Christine Tudor's Avatar
    I have an irritating problem with the installed calendar. I DO NOT put a reminder in when I am creating an event, however once the event is made the damn calendar has AUTOMATICALLY added event reminders at 15 AND 30 minutes. I can't figure out where I need to go to have the calendar NEVER put reminders on. Do you know how it's done?
    05-05-2014 10:36 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    What device do you have? Is it the stock calendar?
    05-05-2014 10:44 PM
  3. Christine Tudor's Avatar
    i have a Samsung Galaxy 3 and yes it is the Device Calendar
    05-07-2014 02:20 AM
  4. mswanger77's Avatar
    Mine has recently started doing that, too. And now, I can't make events different colors…what is going on?
    05-07-2014 11:34 AM
  5. Golfdriver97's Avatar
    You may be getting 2 notifications from both the Samsung calendar, and Google. I would suggest disabling Samsung Calendar and trying Google.
    Sent from my HTC One_M8 using AC Forums mobile app
    05-07-2014 04:16 PM
  6. Christine Tudor's Avatar
    I in fact DO have the google calendar on my phone and din't care for the layout. HOwever since it's still installed on my phone I looked into the google settings and low and behold the reminder was set for 15 minutes. I set the google calendar for 0 reminders and "poof" my problem is corrected in the stock calendar of the SAmsung 3!!!
    Thank you!
    05-07-2014 07:05 PM
  7. Golfdriver97's Avatar
    Thank you!
    No sweat. See you around the forums.
    05-07-2014 08:10 PM
  1. [App] Infographic for Android
    By hidden1611 in forum Android Apps
    Last Post: 05-18-2014, 06:10 AM
  2. Note 3 to "s view screen" when s-view cover folded back.
    By seditious3 in forum Samsung Galaxy Note 3
    Last Post: 05-07-2014, 11:17 AM
  3. Best Phone for carrier unlocking?
    By dxbrooks1 in forum General Help and How To
    Last Post: 05-07-2014, 08:22 AM
