Results 1 to 4 of 4
    Sunmeet Sarna's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default whats wrong with my Samsung screen help!!
    i dont know what it is it may be water or moisture under the screen but i have no idea how it got there since i have not dropped my phone or even got it slightly wet. this issue started after i got my phone screen repaired for 40 which is a good price for a decent screen. whenever i put my phone in my jeans pocket they would get this on the screen sometimes it lasts for 1 day sometimes hours this time its been 3 days and im getting worried. i've tried using a fan and hair dryer but its not working. im going to post a picture to help you see what it is.
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: whats wrong with my screen help!!
    Looks like whoever did the screen replacement didn't get a good seal and its getting moisture buildup when placed in your pocket.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: whats wrong with my Samsung screen help!!
    Looks life moisture to me. Did you replace the screen yourself or did a repair store fix it? I would suggest taking it back if a store did the replacement. Otherwise, open it back up and see if there's anything wrong with the install.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i got the screen replaced from a phone repair shop.
    well thanks for your advice atleast now i know whats wrong with it.
  1. Widgets disappear on my Galaxy S5
    By Angela Rovito Peck in forum Samsung Galaxy S5
    Last Post: 01-28-2017, 11:16 PM
  2. Samsung galaxy note gt n7000 spyware malfunction issue
    By Spyware in forum Samsung Galaxy Note
    Last Post: 08-02-2014, 11:27 AM
  3. What Apps
    By FirstAndroidZ2 in forum Sony Xperia Z2
    Last Post: 05-07-2014, 01:48 PM
  4. Samsung
    By ranganm in forum Samsung Galaxy Note
    Last Post: 05-07-2014, 08:35 AM
  5. My Samsung Galaxy Tab 3 8.0 turns itself off during the night
    By PhilWright41 in forum Samsung Galaxy Tab 3
    Last Post: 05-07-2014, 07:47 AM
