1. meashish's Avatar
    want to changeover android device to other android device , which is the best apps-tool-pc client
    that support to restore like old device
    I want must system settings & most priority for all email account settings-information for push-exchange-imap-pop )
    trying apps - gcloud system settings taken but not restore all of old settings
    - my backup to sd card restore settings but not proper , also not support restore to other device in free version
    - Samsung kies restore only same device, email-apps-other preferences not restore to other device
    also as per google account it restore only apps not any apps data or any other settings.
    how can I take apps+data backup without root ?
    05-08-2014 02:45 AM
  2. srkmagnus's Avatar
    You can't make a complete system image backup of one device and transfer to another if the devices are not the same. However, depending on if you are rooted or not, you have options:
    Helium - Play Store - Does not require root; However, if you are not rooted then you will need to use a desktop client, which is provided on the website of the developer. The App does not need to be used along with the desktop client if you are rooted.
    Titanium Backup - Play Store - Both require root to perform most of the backup and restore functions, such as App data.
    Keep in mind that certain system level backups can't be restored to the new device without there being compatibility issues or crashes. Let us know if you have any questions.
    05-08-2014 10:08 AM
  3. meashish's Avatar
    I don't want to Root also helium app required pc or mac connection that's I don't want every time n titanium is nice but for root.
    So my main need to restore system settings email account settings n apps data if possible without root.
    Still in android os backup- restore part are missing like apple do with itunes - icloud.
    I like android os its superb customizes enable but one thing is backup all thing for restore n change over to other device.
    Also I have read google takes apps data + wifi password but I never seen when restore.
    05-24-2014 07:31 AM
  4. Rukbat's Avatar
    Not possible.
    05-24-2014 09:24 PM
  1. Does 4G LTE Symbol is shown in the device? Samsung Galaxy S5
    By pepejjla in forum Samsung Galaxy S5
    Last Post: 01-19-2015, 07:36 PM
  2. Replies: 2
    Last Post: 05-08-2014, 02:13 PM
  3. Replies: 5
    Last Post: 05-07-2014, 05:56 PM
  4. Replies: 1
    Last Post: 05-07-2014, 05:53 PM
  5. can you use pebble smartwatch on ICS devices?
    By ahawkua in forum General News & Discussion
    Last Post: 05-06-2014, 09:10 PM
