1. pre1561's Avatar
    It seems as though Google update to Gmail has messed it up. Gmail will no longer open attachments on my Note 3 or my wife's S4. I switched to the Samsung email app and attachments open without a problem, is anybody else having the same problem? I have checked the settings in the Gmail app and can't find anything wrong there. I also sent "feedback" to Google. Thanks.
    Sent from my SM-N900P using AC Forums mobile app
    05-09-2014 06:06 AM
  2. VDub2174's Avatar
    I just sent myself an email from my word address and I was able to open the attachment............on the second try.....lol
    05-09-2014 07:02 AM
  3. B. Diddy's Avatar
    What kinds of attachments are you trying to open? Perhaps the default app to open attachments needs to change. Try going to Settings>Apps, tapping the Menu button, and tapping on "Clear all app preferences." Then try opening the attachment again, and see if it prompts you to select a default app to open with.
    I also wonder if the recent updates to Google Drive have any impact. If the phone was relying on Drive to view an attachment, you might need to install the new Docs and Sheets apps, since Google is now breaking up the various components of Drive into separate apps. This older article does mention that Google Drive is integrated with Gmail for attachments: Gmail Users No Longer Need To Download Attachments, As Google Drive Gets Baked Into The Inbox | TechCrunch
    05-09-2014 11:59 AM
  4. Bid's Avatar
    I need help with this exact same thing! I'm in Australia if that makes any difference but I've just tried to open a video attachment and image in my Gmail and every single time it shows the screen shot below. This has only just happened this morning! I don't know what I did or what has happened?? Please help as I can't open any of the important attachments I need to!
    The amazing Note 3!
    06-29-2014 07:44 PM
  5. Bid's Avatar
    The amazing Note 3!
    The amazing Note 3!
    06-29-2014 07:45 PM
  6. Bid's Avatar
    My problem was fixed thanks to a suggestion in another thread! They suggested to download the app called MX Player from the play store and it opened up all my attachments perfectly with no problems! Give it a try!
    The amazing Note 3!
    06-30-2014 06:12 AM
  1. adding second gmail account
    By tempsc in forum HTC One M8
    Last Post: 11-02-2014, 10:13 AM
  2. Galaxy S3 Mini: texts showing up in gmail
    By docyanover in forum Samsung Galaxy S3 Mini
    Last Post: 05-24-2014, 05:09 PM
  3. Gmail in Native Email
    By bgl321 in forum HTC One M8
    Last Post: 05-11-2014, 03:19 AM
  4. Gmail android problem
    By dougltc in forum Android Apps
    Last Post: 05-07-2014, 10:04 PM
  5. Gmail Account and Contacts
    By Wintercreek in forum Samsung Galaxy S5
    Last Post: 05-07-2014, 04:22 PM
