1. moshe1442's Avatar
    hello
    I hope you can help me, last week while trying to do some work on my phone I accidentally deleted my phone factory calendar
    I have tried to get it back but with no luck, can anyone help? every time I try to get it back I have several notes:
    can't be found in "my calendars".. missing apk...
    Is there a way to get it back or set phone to the state it was a week ago (like a system restore point on a computer..?!)
    I have a Lenovo a269i with android 2.3.6
    thanks for everything
    M.
    05-09-2014 09:57 AM
  2. Golfdriver97's Avatar
    hello
    M.
    Welcome to the forums. I would suggest trying to find the .apk file. In the search box, type your model and calendar .apk. See if you can find the file to sideload it.
    If you can't I would then suggest Google calendar.
    05-09-2014 10:08 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Just to clarify--are you saying you accidentally deleted the actual Calendar app, or that you accidentally deleted the calendar events?
    Are you rooted? If you're not, then it shouldn't be possible to delete a preinstalled system app like the Calendar app.
    Golfdriver97 likes this.
    05-09-2014 11:56 AM
  4. moshe1442's Avatar
    i deleted the actual calendar app, and i am not rooted
    05-09-2014 02:24 PM
  5. moshe1442's Avatar
    hey
    i cant use google cal. cause my cell always gives me the answer "no calendar found in your 'my calendar' "
    and it opens a blank list which i can't write in it for some reason, nor wil it take any other calendar as my main one
    05-09-2014 02:27 PM
  6. Golfdriver97's Avatar
    Have you checked for the app file to sideload?
    Sent from my HTC One_M8 using AC Forums mobile app
    05-09-2014 03:52 PM
  7. B. Diddy's Avatar
    This is odd, because you can't delete a system app or preinstalled app if you aren't rooted. Are you absolutely sure you're unrooted? If you bought it on eBay or from some other seller, it's always possible the seller didn't tell you the root history.
    So the Calendar app isn't in the App Drawer? Have you checked to see if your phone is able to hide apps? This is a feature of some Samsung devices.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    05-09-2014 03:59 PM
  8. moshe1442's Avatar
    hey
    I have and it's not.. also it is not hidden is any list, it is gone
    the strange thing is that I cant get any other calendar (like goggle..) to be my main calendar
    any ideas?
    05-10-2014 02:46 AM
  9. moshe1442's Avatar
    hey
    no it is not hidden or in a drawer, I have checked and it seems to be gone from any list of apps on the phone
    is there any way to expose hidden apps? because in the "regular way" it isn't showing.. no hidden apps too..
    any ideas how to set "back in time "the phone? or maybe get another calendar to be main? (until know I was not able to do this
    even with google) can I set/download new calendar to sd and set it?
    ideas?
    05-10-2014 02:52 AM
  10. B. Diddy's Avatar
    I'm pretty much stumped, as I don't see how a system app can be deleted on an unrooted phone. The only thing I can suggest right now is a full factory reset.
    Golfdriver97 and moshe1442 like this.
    05-10-2014 03:00 AM
  11. Golfdriver97's Avatar
    I am not entirely sure a reset will help, but I also don't have anything better to suggest, either.
    From an SOKP Nexus 5
    moshe1442 likes this.
    05-10-2014 08:42 AM
  12. ShaggyKids's Avatar
    hey
    You have to have a Google calendar set up in order to use it. Do you have one set up with the Gmail address you use for your phone?
    I don't understand how a system app could be deleted either. Weird.
    Deb from my Note 3
    05-10-2014 10:23 AM
  1. Galaxy S4 S Planner Calendar Notifications Issue
    By wynand32 in forum T-Mobile Samsung Galaxy S4
    Last Post: 09-15-2014, 12:04 AM
  2. Looking for a great Calendar app to use!
    By badwolf_12 in forum Android Apps
    Last Post: 05-21-2014, 11:06 AM
  3. Stock Calendar: No graphics or text in month view
    By Jaycita Byrne in forum Samsung Galaxy S4
    Last Post: 05-07-2014, 02:46 PM
  4. Replies: 2
    Last Post: 05-06-2014, 11:44 PM
  5. How to read back-up calendar entries?
    By trevornbc in forum Samsung Galaxy Note 2
    Last Post: 05-06-2014, 10:48 PM
