I have a Trio Stealth H-10 (MST10-21) that has the android 4.1.1 version software. Two days ago after I had finished using the tablet, I shut the tablet off. Upon restarting the tablet it started very slowly and the first screen that came up was asking what Language I wanted. From then on it was setting up the tablet again just like the first time it was used. I reset all the info. When I went to the app store to re-download my apps, it would not down load anything. I restarted my tablet again and everything started all over. Every time I restart the tablet, everything has to be reloaded. It seems like it is doing a factory reset every time it shuts down.
I have tried doing the usual searches and have not been able to find any thing that resembles the issues I am having. Or maybe I am not wording my searches correctly. Thank you for any help you can give.
