Owning multiple phones?
6sigma
Active member
Dec 6, 2010
39
I use a Nexus5 on TMobile's $30 per month prepaid plan, & I'm thinking of getting a OnePlusOne for experimenting/testing, etc.
My questions are:
  1. Do I simply get a 2nd TMobile SIM at another $30 per month?
  2. Are SIM cards interchangeable so that one day my EDC phone is the Nexus5 and the next it's the OnePlusOne?
  3. If a 3rd phone were ever added (e.g. Project Ara), would I simply repeat the $30 plan for a 3rd TMobile SIM/phone number?
Thanks for any tips or links you can offer.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
You can simply swap the SIM from one phone to the other--no need to get a new line, unless you intend to use both phones at the same time. Both phones use a microSIM (as opposed to a nanoSIM), so they should be interchangeable.
6sigma
Active member
Dec 6, 2010
39
Thanks! I may treat one as a 'production' phone and one as a training ground for rooting, Cyanogenmod, app Dev/testing, etc. But, SIM interchangeability makes this simpler. Again, many thanks.
Sent from my Nexus 5 using Tapatalk
kerokekerol
