1. DJShawnz's Avatar
    I need help! Whenever i open my Tablet and gonna unlock it, I cannot touch or move the "Lock" Icon. Sometimes, i enable the "Finger Pointer", there will be a White Circle(I know there's a White Circle every time you touch) below the Screen even i didn't Point below and there will be like 10 to 17 Finger Pointers then they will Freeze and i cannot use any Programs. I need help please!
    05-11-2014 11:20 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What device do you have? It might be time for a factory reset, and the procedure varies with the make and model of device.
    05-12-2014 02:04 AM
  3. DJShawnz's Avatar
    It's an I-Techie.
    05-12-2014 02:47 AM
  4. B. Diddy's Avatar
    Model number?
    05-12-2014 03:16 AM
  5. DJShawnz's Avatar
    What's a Model Number?
    05-13-2014 12:41 AM
  6. B. Diddy's Avatar
    It's the specific name or code for the device. For example, the Motorola Droid Razr Maxx's model number is XT912. Sometimes a device's model number is actually just its name, like the Nexus 7.
    It can be found in Settings>About Tablet>Model Number. But if you can't access the menu due to your problems, then see if you can dig up the box it came in--that should have the model number on the sticker with the UPC symbol.
    05-13-2014 03:14 AM
  1. HELP Android charges but does not connect to PC
    By kimmandy36 in forum General Android Device Chat
    Last Post: 10-01-2015, 06:16 AM
  2. Google Maps Heats Up My S4
    By TomD in forum Sprint Samsung Galaxy S4
    Last Post: 05-27-2014, 12:58 AM
  3. My wife got this for Mother's Day. Tab 4 10.1"
    By BigMonkey2013 in forum Samsung Galaxy Tab4 10.1
    Last Post: 05-12-2014, 06:11 PM
  4. I'm rooted but i need rom for huawei u8730 t-mobile mytouch q (its 4g if that helps)
    By Will blue in forum myTouch 4G Rooting, ROMs, and Hacks
    Last Post: 05-11-2014, 10:28 PM
  5. Replies: 1
    Last Post: 05-11-2014, 09:15 PM
