1. aceonthewire's Avatar
    Hi All,
    I'm hoping someone can help me. I've just installed 4.4.2 google play edition on my Galaxy S4 (GT-I9505). When i attempt to make a call the screen goes black (i can still see the top task bar (wireless/radio/time)) and i get intermittent vibrations. The call actually processes as my other phones rings, however i hear no audio through the S4. To terminate the call i have to kill the Phone app. The same goes for receiving calls also.
    I'm with Three in the UK and my baseband is: I9505XXUEMK9
    Would anyone be able to identify what may be causing this issue or how to fix? I've tried to go back to stock via Odin however keep getting failed when it attempts to write. I've also tried different USB cables in different ports and different PCs.
    05-12-2014 03:39 AM
  2. Kelly Burby's Avatar
    Hi All,
    Well, It looks like that the problem is with the Play edition ROM itself I think it might be buggy, anyway the solution is to get the stock ROM flashed. I would say try flashing the stock ROM again to your device, I think that you might not be following the appropriate procedure that needs to be followed. Try following all the steps stated over the XDA thread [GUIDE] Unroot/Unbrick, Flash official stock firmware on Galaxy S4 GT-I9500 & I9505 - xda-developers
    05-12-2014 03:52 AM
  3. aceonthewire's Avatar
    Hi Kelly,
    Thanks for your reply. I have just tried again, following each step to the letter in that link, using the stock ROM from that page. I also tried with the PIT as suggested. I still get the FAIL message. Below is a screenshot where it errors.
    Attached Thumbnails Making or receiving calls causes screen to go black and unresponsive S4 UK-screen-shot-2014-05-12-10.20.06.png
    05-12-2014 04:23 AM
  4. pollensa1946's Avatar
    I had exactly that problem of the black screen, no audio when I installed 4.4.2 and was using the BT SmartTalk app. The stock phone app was OK but the SmartTalk app was not. I uninstalled two apps, TrustGo A/V and CleanMaster and the problem was gone.
    05-12-2014 07:22 AM
  5. aceonthewire's Avatar
    This issue happens from a fresh install though, so no other apps installed....
    05-12-2014 07:35 AM
  6. od123's Avatar
    Hi
    I had the same issue a few months ago.
    It is an rooted Galaxy S4 with Google Play Edition - so you get all the OS very early.
    As soon as I installed the latest OS - 4.4.x - I got this black screen.
    I thought it is the proximity sensor - so I asked and got a new phone! Which work great!
    Not being 100% sure - I decided not to install 4.4.2
    But yesterday I did - and ... the black screen is back.
    I tried this trick - I put the phone very close to a strong lamp - the screen is back - I can disconnect the call.
    Away from the light - dark again.
    I read in this forum that there is a setting option to disable the proximity sensor.
    I did not find it on the Google Play Edition.
    Any idea? Any app that control this sensor?
    Any other suggestion (I prefer to keep my phone unrooted)?
    Any why to roll back to the prev OS?
    Thanks
    Ori
    05-21-2014 03:29 PM
  1. Is there a way to get my alarm time on the lock screen?
    By woahohkelsey in forum Samsung Galaxy S5
    Last Post: 07-27-2015, 02:08 AM
  2. Replies: 2
    Last Post: 03-06-2015, 01:25 PM
  3. Replies: 2
    Last Post: 05-12-2014, 11:46 AM
  4. Sony Xperia Z ultra or the Google play edition
    By valapsp in forum General News & Discussion
    Last Post: 05-12-2014, 09:48 AM
  5. Is it safe to disable Message+?
    By CannedBullets in forum HTC One M8
    Last Post: 05-12-2014, 07:08 AM
